Problem with DVD player software
I don't often play DVDs on my G5 iMac, but when I tried to today I get the error
There was an initialization error
The player requires a newer version of the DVDPlayback framework [-70103]
I'm not too sure what this framework it referrs to is
Any ideas?
Regards
Mike
Hi Mike,
can i just check what version of OS X are you using ?
I take it that DVD's did use to work, is it just one DVD that doesn't work, or all DVD's ?
Did this stop working after a recent software update !
edit:
latest version can be found here !
Hi Rick
I I'm on 10.4.2
I tused to work fine when I tried it. I've just run software update, and despite it being set to run weekly, there's a host of updates there, including one for the DVD player. When I tried to install them I've a few red exclamation marks next to some on them, including the DVD update, and now wants to reboot. I'll let it restart and try the update again
I'll report back
Mike
No problem,let us know how it goes. You might want to run repair permissions once all the updates have been done.
It seems OK now.
I guess a previous automatic update must have broken it and I only noticed today. A few software updates and restarts seems to have cured it
I guess I should have tried software update first but the phrase that mentioned frameworks threw me as it was new to me
Cheers
Mike
No problem, 'frameworks' are part of the underlying 'code' that Mac OS X is built on...can't think of a better way of describing them ?
Apple sometimes 'break things' in one update and then fix them in the next...
DVD drive problem 8
iMovie to iDVD slideshow problem 3
Dvd Cd reading problem 1
DVD Player Problem 1
DVD writer problems 5
Dvd problem mac pro 0
iMac DVD Problem 7
Quicksilver 2002 dvd problem 1
