I have an iBook G4 which has just recently started playing up. It appears to go to sleep of its own accord and will not wake from it. It rarely boots up and when it does will just go off again. It seems to hang up at a very early stage when booting and the fan quite often stays on and the machine does not respond at all and requires the battery to be removed to reset. Another thing is charging, it doesn't! It runs from the battery and the mains but does not charge.
I've read a few posts that seem to have similar problems so have tried things such as resetting the PMU but it didn't solve the problem.
I don't know whether it is a hardware or software problem. Can anyone shed any light on the matter?
Cheers
Cheers
