Good day,
I have a problem connecting an iMac to the network.
My ADSL line is connected to a Netgear DGN220M router. An Airport Extreme, Mac mini (late 2012) as well as an iMac (mid 2011) is connected to the network. (A number of iPad and iPhones are also connected.)
When waking the iMac (or sometimes Mac mini), Safari seems not to be connected to the internet. I would then use network - assist me - diagnostics - etc to fix the problem. (I then usually use my iPad to acces the internet, while the “fixing” is in process. So there in internet ) It normally takes 3 to 5 minutes for the iMac connection problem to be solved.
A related problem. I access my email through Gmail and Safari. In some cases Gmail wil not connect to the internet. I would however be able to get access to the internet through other tabs. I then have to follow the same diagnostics proces to reset the iMac internet connection in order to get Gmail connected.
Notes:
Pieter
Notes:
- This does not happen on every wake event. It is random for both problems.
- Generally my adsl connection is extremely slow. (This is a service provider problem)
- I am using Network Speed Viewer.
- The problem is most prominent on the iMac.
- The problem is more frequent after installing Yosemite.
Pieter
