Printing Issue
New to Mac. Just purchased macbook pro today. My problem is that I have an excel spreadsheet that I use for invoicing. I use Excel 2016 from Office 360 on the mac. I used the same sheet in Windows. The problem is that when I print it, it doesn't format out right. Everything is larger so it prints 2 pages instead of one with the last column going on the second page. This also happens if I print from my iPad Pro. It prints fine from the windows computer.
Is there something that can be done to correct this, other than reformatting the spreadsheet?
There are a few options to correct this:
-In the Print dialog box, you could use the Scale to fit: section to set it to print one page wide.
-Use the set print area command
-It could also be that the spreadsheet uses a font that is not installed on the Mac/iPad Pro, which is substituting a font of a larger size. You could change the font size to a point or two smaller - i.e. 12 pt down to 11 pt or 10 pt.
I don't have access to Excel 2016 here at home, but I can check at the office tomorrow and let you know of anything additional.
Thanks. I did cut down on the size of the table. Works but looks funky. NowI need to find out if fonts on my windows computer will work on the Mac. I really like the Macbook, but the transition from a person who has been using windows since 3.1 on floppies, it's a whole new learning curve!
Yes, it is a totally different workflow and system logic than Windows.
Most Windows fonts will probably not work. However, Office fonts installed with Office 2016 should be the same/similar to the ones for the Windows version of Office.
What font was originally used in the Windows Excel file?
