- May 22, 2020
Hello everyone!
I've got a baffling issue here. I bought a few Powebook 160's a little bit ago, all running System 7.1. However, one of them stopped booting one day and I assumed that the old hdd went bad. However, when I tried to boot off of an Apple install disk with system 7.1, the computer gives this error:
"This startup disk will not work on this Macintosh model. Use the latest Installer to update this disk for this model. (System 7.1 does not work on this model; you need a newer version that does.)"
This is baffling to me, since the machine was just running 7.1, and System 7.1 is listed as a supported OS.
I also tried creating a boot disk from a working Powerbook 160 running system 7.1, and I received the same error. I'd like to try booting it with a newer system, but I don't have any boot disks newer than System 7.1 at the moment.
Does anyone have any ideas what might be causing this issue?
