Please Help w/Powerbook
I recently dropped my camera on my mac powerbook. the screen became distorted.
I started using an external apple display and it was working fine.
All of the sudden the screen starts to look "noisy". It goes away after awhile but is stil frustrating. Any simple solutions?
Thanks
Nope, you have damaged your logic board /screen. If you think its worth it, powerbook is a very old model, then take it to an Apple service Centre near you.
Thanks,
That's what I figured. Would you recommend buying a used Mac laptop or iPad?
If so what is the "oldest" one I can buy that would be worth it.
A new Mac is just not in my budget right now.
Thank you
