Hi all,
I have had this MacBook Airlate 2013 model since it came out and it has always worked flawlessly. Up until a few weeks ago it started turning off randomly/not sleeping properly.
As anyone who knows what they're doing would do I reset the SMC and this temporarily fixes the issue.
I just backed up and wiped Macintosh HD And changed the name to
NATE2017
While reinstalling OS X Sierra it keeps doing what is pictured then shutting down about halfway thru installation..
What could possibly be going on!??
If you can't see attachment it's here https://imgur.com/gallery/HvQRR
NATE2017
