I wanted to partition my 1TB hard disk with disk utility , all I had in that disk was 400 GB data so I wanted to partition it into two partitions of 500MB each , I successfully dragged the slider to adjust sizes and started the process, unfortunately there was power cut and I had to restart the comp after which now it show a full partition of 999GB and almost entire partition barring a few MBs is blue , that is , it is showing that almost the entire drive is full with data which is not true, so obviously when I try it doesn't partition and all tabs on the partition page are greyed..... while trying to partition I get this error too :
Partition failed with the error:
Couldn’t modify partition map because file system verification failed.
How should I correct it now ......I don't have any recovery data on time machine
