- Jul 29, 2013
Ordinarily Option+Shift+Left/Right will allow you to select text a word at a time, but this no longer functions. I can select text a letter at a time (Shift+Left/Right), skip forward or backward in text a word at a time (Option+Left/Right), and use other text selection combinations (e.g., Cmd+Shift+Left/Right; Shift+Up/Down). All of the keys work fine in every other context, but this one combination doesn't work. It doesn't matter which Option or Shift keys are used; I've tried every combination to no avail. The cursor doesn't respond at all. This is persistent across all applications.
I've searched high and low and can't find a solution for this, and none of my own tinkering with keyboard or accessibility settings has made a difference. Given that I work with text and code all day, this slows my workflow down considerably and is incredibly annoying. Please help!
I'm on a Mac Book Pro Retina (Mid 2012) running OS X 10.8.4, in case it matters.
