Not seeing how to disable right-click menu release click
This has caused countless accidental clicks in my Mac usage, from Sierra to Big Sur. For the life of me I can't figure out how to disable right-click menu release click.
For instance: I right-click (using mouse, I don't use trackpad) somewhere, a menu opens up, which I want, but then if I accidentally release right-click while the mouse pointer is hovering on a menu item, it selects that menu item. This is driving me crazy.
This doesn't happen on Windows; releasing right-click while hovering on a menu item doesn't activate it, I have to left-click it. This seems like sensible, and accident-proof, behavior. I'm seeing nowhere on Mac or online how to just turn off right-click release activation.
Try System Preferences -> Mouse -> Point & Click. Then uncheck “Secondary click.”
Point & Click where?
I'm on macOS Big Sur Version 11.6.1. Which version are you on?
Okay, here is my Mouse preferences window in Big Sur 11.6.2.
I don’t have 11.6.1 installed, so that might be the issue. Is your mouse Apple-branded or third-party? Is anyone else running 11.6.1? Maybe they can check to see…
