Hi fellows,
Just today i have installed an application which was to do with sound switching , called "soundflower" once iv installed and run it there was an option "create multiple sound switch" did chose and start to creating a multiple, as soon as it started my sound card panel display as " no sound card founded "
and my sound icon on the top bar turned to light gray.
i have searched for a solution which i cam acros this >>
Double click on that and when it opens you will see your hard drive (usually Macintosh HD) on the left. Highlight your hard drive and click on Verify Disk on the far right. If that is OK click on Repair Permissions on the left. If Verify Disk is not OK try to Repair. If Repair is successful then Repair Permissions if it is not successful let me know.
But problem still remains
Appreciated for any reply.
Thanks,
Thanks,
