I spent an hour searching forums and I opened script editor to try and figure it out by doing... but I got scared and ran back to the forums.
I want either a folder action or folder action/automator combo that will run automatically when a new item is put into a folder. I just want that item to be renamed to fit sequentially with the rest.
So for example I have 542 images in the file. They are name 001.jpg-542.jpg respectively. I want the next image I put in the file to automatically be renamed to 543.jpg
How would I do that?
