Need Help with Expose and Spaces Error
whenever i try to open expose and spaces from system preferences, the entire system preferences closes with an error report that looks like this:
Process: System Preferences [305]
Path: /Applications/System Preferences.app/Contents/MacOS/System Preferences
Identifier: com.apple.systempreferences
Version: 7.0 (7.0)
Build Info: SystemPrefsApp-1750100~19
Code Type: X86-64 (Native)
Parent Process: launchd [251]
Date/Time: 2012-07-18 02:15:30.421 -0700
OS Version: Mac OS X 10.6.8 (10K549)
Report Version: 6
Interval Since Last Report: 400791 sec
Crashes Since Last Report: 7
Per-App Interval Since Last Report: 198829 sec
Per-App Crashes Since Last Report: 7
Anonymous UUID: 786B084B-8F94-42BA-BC4B-6268C3147BD3
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000115fd9a20
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Application Specific Information:
objc_msgSend() selector name: willSelect
objc[305]: garbage collection is ON
all other apps of system preferences work fine. it's just the expose and spaces that wont work.
ive tried deleting the 'com.apple.systempreferences.plist' and rebooting my computer but the same error keeps popping up.
can anyone help with this? thanks in advance!
Hello and welcome. Sorry we didn't get back to you sooner.
I see you deleted one of the plist files. There are a couple more for you to try deleting from your User folder:
~/Library/Preferences/com.apple.systempreferences.plist (the one you deleted)
~/Library/Preferences/ByHost/com.apple.systempreferences.xxxxxxxxxxxx.plist (the xxxxxxxxxxxx will be your Mac's Ethernet MAC address)
~/Library/Caches/com.apple.systempreferences (the whole folder)
Try deleting all of these and restarting. If the issue isn't resolved, try creating a test user and see if it happens when logged into it. If it does, then it's a system-wide issue and will probably require a reinstall.
