- Feb 15, 2006
About a week ago I started having this problem where my screen keeps going blurry. When the desktop appears after startup, not all the pixels will be displayed, some of my icons don't appear/only partially appear, the dock's not fully displayed either etc. (Sometimes the problems occur right away during startup and the picture's fuzzy all the way- however, after a few stops/restarts I can get it so that the screen's only a little wierd once the desktop's appeared).
Also, once it's loaded, the screen will 'shudder' for a few seconds and blur, then it will stop and do it again in a minute or so. I can still use my computer, all the software seems to be functioning normally, it's just the screen.
I thought at first it was a virus but I've updated my virus software and nothing seems to have been detected. I'd be really grateful if anyone has any ideas as to what's wrong and what I can do to fix this.
