I have a new Macbook pro - Sequoia 15.2
My mouse just disconnects and I have to keep restarting the Macbook.
The pad, the mouse, both bluetooth or wired do not respond.
I don't know what is going on?
Sounds like the MacBook is quite new and should be under AppleCare. I suggest getting an appointment at your nearest Apple Store or AASP for repair. Trying to do too much troubleshooting on your own might compromise the warranty. This is coming from a previous AppleCare Service Provider. Good luck.
Yes it is new.
However I think I have solved the problem.
I went through various settings, after noticing the cursor was leaving the screen.
It was set to move to an adjacent computer.
I cancelled this and, thouch wood, it has been fine for a few days now.
