on idle
if file "Macintosh HD:Users:KmanCatocumentsocument1.cwk" is (open) then
tell application "AppleWorks 6"
open document "Macintosh HD:Users:KmanCatocumentsocument2.cwk"
end tell
end if
end idle
<<script>> doesn't understand the "open" message
This would be an excellent post for MacScripter.net:
Not a bad post for here either...
kmancat said:No, I have not posted it in MacScripter...
The documents are just word processing .cwk's (the extension for AppleWorks). If it would make it easier, I could turn them into MS Word files...
kmancat said:That isn't what i was thinking, but it works better than what i wanted! Thanks!
(wow...why didn't I think of that!?)
casdvm said:Now Ric, don't get yourself all excited about my offering up MacScripter.net. I consider myself a slightly above average scripter, especially with AppleWorks. It just so happens that there are about a half dozen top notch scripters that check into MacScripter along with a couple hundred average types like myself. It is a great forum for more involved scripting issues, which I believe this may very well be.
I have been trying to keep an eye on your AS forum here, simply because I like scripting and would be happy to try to assist anyone that needs it.
Craig
