Monitor has started going blurry
Hi, I'm running a Dual 2.3 GHz G5 PowerPC with Mac OS X 10.4.11 and my screen has suddenly started going blurry. It may have been going for a while but it is only this morning that it has become obvious. I have switched monitors and the problem is still a problem, so it isn't the monitor.
I've created a new user account to test if it goes throughout the system but it appears that the new user account is perfectly fine, it's just mine. I know this suggests it's a software problem than hardware problem but how do i find out what exactly is causing it and how do i fix it?
Any help would be great!
Thanks
Maria
It's ok people.. problem solved. Somehow my screen Zoom In turned itself on, was juse a case of holding Ctrl and scrolling back out.
Phew....thought i was losing my eyesight or something!! :)
