SOLVED Microphone for iMac.
Good morning: I would appreciate if any body could tell me how to make work an external Microphone on an iMac, because I just find a jack for headphones .
Thanks
OK, thanks.
From that description, it looks like an iMac (Retina 4K, 21.5-inch, 2017). Those models and newer only have an audio out/headphone jack - no audio input. So, you'll need a USB microphone, or a USB/Thunderbolt audio interface to connect the mic to.
What brand/model is the mic?
Movo Universal Lavalier USB Microphone for Computer with USB Adapter Compatible with Laptop, Desktop, PC and Mac, Smartphones, Cameras, Podcasting, Remote Work and Laptop Microphone (20-Foot Cord)​
I had to return it because it did not work
If you have a pair of AirPods or AirPods Pro, and it’s paired with your Mac, you can try them first. They work well! And you don’t have to wear both ear pieces.
