I recently tried to (manually, not using bootcamp) set up dual boot on a MBP by doing the whole process of re-partitioning, etc. After the original OSX partition was resized, everything still worked fine.
During the installation of the second partition (a Linux one), nothing on the OSX partition was touched - only the new, empty partition left over from shrinking the OSX partition, but after quitting the process half way (an error of some sort occurred and the installation hung), the MBP no longer boots/only boots to a black screen.
This is despite trying every single different boot option available from here, none of which got me past the black screen. Note that the startup chime still happened though, just nothing after (you can still see the screen's backlight come on). However, the keyboard backlight doesn't come on, and the Caps Lock key does not work either (green light doesn't toggle), so it doesn't appear to be a case of only the display not showing anything.
I'm thinking of trying to image the disk from scratch from a working MBP, but would like to avoid taking them apart if possible - what are my options here?
Cheers.
Cheers.
