Memory problem, please help.
Hello, I have a MacBook Pro (early 2011) , had the 3 beeps problem (original ram), the MBP starts only if i have only one of the two memory sticks inserted, it doesn't seem like a memory stick or memory slot problem (tried all the configurations) , please help.
Not a lot you can do, take it to an Apple Service Centre near you if you think its the slot. If its the RAM replace it, Important: It takes just 30 volts to burn a RAM chip, thats a small fraction of our normal static charge. Ensure you use a grounding wire and anti-staic mat while handling RAM.
