I have a MBP 5,3 with Sierra installed since a couple of month without problems.
After a reboot of my MBP I am stuck in the login screen as trackpad and keyboard are not respodning any more.
USB ports are "dead", means I can not operate external devices on it.
Starting the "rescue" partition is not possible as the option is crossed out, means the icon with the crossed cricle appears. Bes..ides I can use the trackpad on the screen when to chosse the start partition.
However, I can start the installer program from a USB stick - it is not a dead USB port I assume.
With system profiler from the installer program I can see that there is no "USB" under hardware - could it be that I lost the system driver of MACOS?
I can use the Terminal as well etc. (from the Disk utility)
I did not install anything before the reboot.
Does anybody have an idea what to do to get the SUB working again without reinstalling?
The ususal stuff I did already, like SMC/NVRAM reset, using disk utility to repair file access rights , reboots etc.
Thak you for any hint fro a solution.
Thanx, cal
Thanx, cal
