Need to ask some questions:
2. What exact Mac OS are you running?
3. Have you ever done any disk cleanup/maintenance/repairs using software? You actually can do quite a lot of disk cleanup on your own, and there are some excellent products available (both free and commercial) that can help you with those tasks.
4. This is critical: are you making backups to an external device/ if so, what software do you use for that task?
It seems this just happened. What you can try is to shut down your machine, and shut down the router and/or modem. Your ISP usually has specific instructions as to how to do that, how long you keep them off, and then the sequence that you turn them back on.
