My MacPro 3,1 G5 has Mac OSX Server 10.6.3 loaded on a 500GB HD, I can move it to any of 1-4 drive bays and it mounts and loads my system. But when I try to put in a second hard drive in 1-4 it will not mount at all. I know the second had drive is good because I can take it out and put it on a USB convert kit and the 2nd drive boots just fine. What would cause me not to be able to use a second hard drive internally on any slot 1-4 but the first one hard drive boots just fine?
