Macos bootable problems
Hello would like advice on what I am doing wrong in making macos bootable usb.
I had two working ones.
Now when I make the new ones that don't work they just come up with a circle with line through it.
Any advice would be great.
Thank you
-Can you give us the process that you used to create the bootable USB installers?
-USB flash drives?
-Where did you get the OS X/macOS installer applications?
16gb usb
Terminal cmd commands I will find codes later today.
From osxdaily.
And couple other mac websites but not the app store.
So update guys. Thank you all for the help
I have some working Boot able now.
I just need to find a copy of el captain or serria.
