- Oct 21, 2021
I set up a router (Verizon FIOS G1100) at my dorm with the upstream being the uni network (eduroam) so that I can get my Google Home Mini to work and iMazing’s automatic iPhone backups to work over WiFi (usually, the devices wouldn’t be able to discover each other since eduroam doesn’t have UPnP or something). I basically did what this Reddit comment suggested, and everything works perfectly except after ~20-30 mins or so, my MacBook’s WiFi suddenly slows to a crawl and, shortly after, stops working. It gets a bit weird:
Btw, I got this kernel panic by waiting some time after the WiFi stopped working and attempting to reboot (it seems to get slower and slower after the WiFi stops working until it, I assume, just kernel panics on its own, which is why it tells me it crashed overnight when I turn it on for the first time in the morning). Don’t know if it will be useful or not, but here it is:
ping
can’t connect to IP addresses on the LAN (or the WAN; for example, ping google.com
fails) (ping 127.0.0.1
works, though), browser tabs crash, the network page in system preferences takes a while to load, and when I try to shut down, some programs (e.g., Spotify) hang and I have to force quit them. However, after rebooting, everything works for another ~20-30 mins, and then it happens again. This whole conundrum does not occur on non-extender networks (e.g., eduroam). I feel like this is a software problem because I remember having a similar issue at home (I connected my computer via Ethernet to my extender and, after some time, it too would have WiFi not working and programs freezing up) and my phone connects the whole time to the router with no issue. Any pointers on how I could go about debugging/fixing this?Btw, I got this kernel panic by waiting some time after the WiFi stopped working and attempting to reboot (it seems to get slower and slower after the WiFi stops working until it, I assume, just kernel panics on its own, which is why it tells me it crashed overnight when I turn it on for the first time in the morning). Don’t know if it will be useful or not, but here it is:
Code:
panic(cpu 4 caller 0xffffff80163fe9fe): watchdog timeout: no checkins from watchdogd in 302 seconds (331 totalcheckins since monitoring last enabled), shutdown in progress
Backtrace (CPU 4), Frame : Return Address
0xffffffa0862f3c00 : 0xffffff801308cfdd
0xffffffa0862f3c50 : 0xffffff80131d3fd3
0xffffffa0862f3c90 : 0xffffff80131c45ca
0xffffffa0862f3ce0 : 0xffffff8013031a2f
0xffffffa0862f3d00 : 0xffffff801308c7fd
0xffffffa0862f3e20 : 0xffffff801308caf3
0xffffffa0862f3e90 : 0xffffff801389ce34
0xffffffa0862f3f00 : 0xffffff80163fe9fe
0xffffffa0862f3f20 : 0xffffff80163fe2ec
0xffffffa0862f3f50 : 0xffffff801476565f
0xffffffa0862f3fa0 : 0xffffff801303113e
Kernel Extensions in backtrace:
com.apple.driver.watchdog(1.0)[4CFADD2A-613E-320D-AD14-9C9379E87CB7]@0xffffff80163fc000->0xffffff80163fefff
com.apple.driver.AppleSMC(3.1.9)[41EE0F43-5968-345F-9A44-9C865EA40A7F]@0xffffff8014756000->0xffffff801476efff
dependency: com.apple.driver.watchdog(1)[4CFADD2A-613E-320D-AD14-9C9379E87CB7]@0xffffff80163fc000->0xffffff80163fefff
dependency: com.apple.iokit.IOACPIFamily(1.4)[59A305C2-E322-3EA6-B8DB-475512053CDE]@0xffffff8015644000->0xffffff8015645fff
dependency: com.apple.iokit.IOPCIFamily(2.9)[4E85D41F-6AD7-3C24-911C-A8B80B599F86]@0xffffff8015b6c000->0xffffff8015b94fff
Process name corresponding to current thread: kernel_task
Boot args: kext-dev-mode=1,amfi_get_out_of_my_way=0x1
Mac OS version:
20G165
Kernel version:
Darwin Kernel Version 20.6.0: Mon Aug 30 06:12:21 PDT 2021; root:xnu-7195.141.6~3/RELEASE_X86_64
Kernel UUID: C2591F4E-EE82-33CC-8C59-DB81D9AD80DD
KernelCache slide: 0x0000000012e00000
KernelCache base: 0xffffff8013000000
Kernel slide: 0x0000000012e10000
Kernel text base: 0xffffff8013010000
__HIB text base: 0xffffff8012f00000
System model name: MacBookPro14,3 (Mac-551B86E5744E2388)
System shutdown begun: YES
Panic diags file available: YES (0x0)
Hibernation exit count: 0
System uptime in nanoseconds: 15521631647992
Last Sleep: absolute base_tsc base_nano
Uptime : 0x00000e1de957401f
Sleep : 0x000009b38437cb7a 0x0000000088c865f1 0x0000092bece81603
Wake : 0x000009b390f41019 0x0000000088da98c2 0x000009b38b66bf15
last started kext at 10667459085426: >usb.cdc.acm 5.0.0 (addr 0xffffff7fadba8000, size 8192)
last stopped kext at 10831505695218: >!UAudio 405.39 (addr 0xffffff7fadbac000, size 315392)
loaded kexts:
com.google.drivefs.filesystems.dfsfuse 45.3.0
com.Cycling74.driver.Soundflower 2
com.objective-see.lulu 1.2.3
@filesystems.smbfs 3.6.1
@fileutil 20.036.15
@filesystems.autofs 3.0
>!AHIDALSService 1
>AGPM 122.1
>!APlatformEnabler 2.7.0d0
@kext.AMDFramebuffer 4.0.6
>X86PlatformShim 1.0.0
@kext.AMDRadeonX4000 4.0.6
@kext.AMDRadeonServiceManager 4.0.6
>AudioAUUC 1.70
>!AGraphicsDevicePolicy 6.3.5
>!AUpstreamUserClient 3.6.8
>!AHDA 283.15
@AGDCPluginDisplayMetrics 6.3.5
>pmtelemetry 1
|IOUserEthernet 1.0.1
>usb.!UUserHCI 1
>!A!IKBLGraphics 16.0.5
>SMCMotionSensor 3.0.4d1
>!A!IPCHPMC 2.0.1
|IO!BSerialManager 8.0.5d7
@Dont_Steal_Mac_OS_X 7.0.0
>!AHV 1
>!ADiskImages2 1
>AGDCBacklightControl 6.3.5
>!A!ISlowAdaptiveClocking 4.0.0
>!AMuxControl 6.3.5
>!AEmbeddedOSSupportHost 1
>eficheck 1
>!AGFXHDA 100.1.433
>!AMCCSControl 1.14
@kext.AMD9500!C 4.0.6
>!A!IKBLGraphicsFramebuffer 16.0.5
>!AThunderboltIP 4.0.3
>!AFileSystemDriver 3.0.1
@filesystems.tmpfs 1
@filesystems.hfs.kext 556.100.11
@BootCache 40
@!AFSCompression.!AFSCompressionTypeZlib 1.0.0
@!AFSCompression.!AFSCompressionTypeDataless 1.0.0d1
>!ATopCaseHIDEventDriver 4050.1
>AirPort.BrcmNIC 1400.1.1
@filesystems.apfs 1677.141.2
@private.KextAudit 1.0
>!ASmartBatteryManager 161.0.0
>!AACPIButtons 6.1
>!ARTC 2.0
>!ASMBIOS 2.1
>!AACPIEC 6.1
>!AAPIC 1.7
@!ASystemPolicy 2.0.0
@nke.applicationfirewall 311
|IOKitRegistryCompatibility 1
|EndpointSecurity 1
@kext.triggers 1.0
@kext.AMDRadeonX4100HWLibs 1.0
@kext.AMDRadeonX4000HWServices 4.0.6
>DspFuncLib 283.15
@kext.OSvKernDSPLib 529
|IO!BHost!CUARTTransport 8.0.5d7
|IO!BHost!CTransport 8.0.5d7
|IOAVB!F 940.4
@plugin.IOgPTPPlugin 985.2
|IOEthernetAVB!C 1.1.0
>X86PlatformPlugin 1.0.0
>IOPlatformPlugin!F 6.0.0d8
@!AGPUWrangler 6.3.5
|IOSlowAdaptiveClocking!F 1.0.0
>usb.IOUSBHostHIDDevice 1.2
>!AGraphicsControl 6.3.5
>!A!ILpssUARTv1 3.0.60
>!A!ILpssUARTCommon 3.0.60
>!AOnboardSerial 1.0
|IOSerial!F 11
>!AHDA!C 283.15
|IOHDA!F 283.15
|IOAudio!F 300.6.1
@vecLib.kext 1.2.0
>!ABacklightExpert 1.1.0
|IONDRVSupport 585.1
>!ASMBus!C 1.0.18d1
@kext.AMDSupport 4.0.6
|IOAccelerator!F2 442.9
@!AGraphicsDeviceControl 6.3.5
|IOGraphics!F 585.1
>!AThunderboltDPOutAdapter 8.1.4
>usb.cdc.ncm 5.0.0
>usb.cdc.ecm 5.0.0
>usb.!UiBridge 1.0
>usb.cdc 5.0.0
>usb.networking 5.0.0
>usb.!UHostCompositeDevice 1.2
>!AThunderboltDPInAdapter 8.1.4
>!AThunderboltDPAdapter!F 8.1.4
>!AThunderboltPCIDownAdapter 4.1.1
>!ABSDKextStarter 3
|IOSurface 290.8.1
@filesystems.hfs.encodings.kext 1
>!AActuatorDriver 4440.3
>!AHIDKeyboard 224
>!AMultitouchDriver 4440.3
>!AInputDeviceSupport 4400.35
>!AHS!BDriver 4050.1
>IO!BHIDDriver 8.0.5d7
>!AHSSPIHIDDriver 61
>!AHSSPISupport 61
|IO80211!F 1200.12.2b1
|IOSkywalk!F 1
>mDNSOffloadUserClient 1.0.1b8
>corecapture 1.0.4
>!A!ILpssSpi!C 3.0.60
>!AXsanScheme 3
|IONVMe!F 2.1.0
>!AThunderboltNHI 7.2.8
>!AHPM 3.4.4
|IOThunderbolt!F 9.3.2
>!A!ILpssI2C!C 3.0.60
>!A!ILpssDmac 3.0.60
>!A!ILpssI2C 3.0.60
>!A!ILpssGspi 3.0.60
>usb.!UXHCIPCI 1.2
>usb.!UXHCI 1.2
>usb.!UHostPacketFilter 1.0
|IOUSB!F 900.4.2
>!AEFINVRAM 2.1
>!AEFIRuntime 2.1
|IOSMBus!F 1.1
|IOHID!F 2.0.0
$!AImage4 3.0.0
|IOTimeSync!F 985.2
|IONetworking!F 3.4
>DiskImages 493.0.0
|IO!B!F 8.0.5d7
|IOReport!F 47
|IO!BPacketLogger 8.0.5d7
$quarantine 4
$sandbox 300.0
@kext.!AMatch 1.0.0d1
|CoreAnalytics!F 1
>!ASSE 1.0
>!AKeyStore 2
>!UTDM 511.141.1
|IOUSBMass!SDriver 184.140.2
|IOSCSIBlockCommandsDevice 436.140.1
|IO!S!F 2.1
|IOSCSIArchitectureModel!F 436.140.1
>!AMobileFileIntegrity 1.0.5
@kext.CoreTrust 1
>!AFDEKeyStore 28.30
>!AEffaceable!S 1.0
>!ACredentialManager 1.0
>KernelRelayHost 1
|IOUSBHost!F 1.2
>!UHostMergeProperties 1.2
>usb.!UCommon 1.0
>!ABusPower!C 1.0
>!ASEPManager 1.0.1
>IOSlaveProcessor 1
>!AACPIPlatform 6.1
>!ASMC 3.1.9
|IOPCI!F 2.9
|IOACPI!F 1.4
>watchdog 1
@kec.pthread 1
@kec.corecrypto 11.1
@kec.Libm 1
