 - Dec 10, 2012
I have a 13" MacBook Pro 2011. A few days ago I was trying to open TextEdit to type some notes & noticed my Mac was working much slower than usual. I figured this was due to having several programs open as well as a couple minimized browser windows. While trying to close out of some of these programs, my computer froze and I was forced to shut down by holding down the power button. A little later, I powered up my Mac and was unable to get past the white screen with the grey apple, spinning gear, and the loading bar beneath it that remained empty. I have already attempted a PRAM reset a couple of times, with no result. I have also made several tries at a Safe Boot. The first time I tried safe boot by holding down shift key, a window popped up instructing me to shut down my computer & restart normally. I did this and the only noticeable change was that the loading bar at the bottom of the screen filled up approx. 25% of the way before it ceased to load any further. I waited an hour just in case, but it remained unchanged. The second & third time I tried to reboot to safe mode, the result was a grey screen indicating a kernel panic, inability to boot system and the following text across the screen indicating a fault in the driver-
Panic(cpu 0 caller 0xffffff800064ba7b):"unable to find driver for this platform:\"ACPI".\n"@/sourceCache/xnu/xnu-1699.26.8/iokit/kernel/IOPlatformEXpert.cpp:15 04. I have read on several blogs that people are receiving these kernel panics as the result of a thunderbolt update, however I have not installed any updates in months, and never installed a thunderbolt update to my knowledge, so whatever's going on with my Mac isn't likely due to any updates. Also, I have been looking for recovery CDs for my Mac, and have been unable to find any. I actually don't remember ever seeing any CDs in the box with my computer and I bought it new @ Best Buy. I am still trying to find the black folder that came in the box with my Mac, that contains manual, etc., assuming they may be in there. I would appreciate any suggestions as to how to repair my computer (hopefully without losing my data). I'm also curious to learn what may have caused this issue so that I might avoid a repeat of this situation in the future. Thank you
