Hi Everyone! My Macbook Pro's USB Port is Not Working. I tried in all ports but facing same issue. I resetted the USB port but still facing same issue.
-Which exact MacBook Pro?
-Which version of macOS?
-When you say you reset the USB port, do you mean your performed an SMC reset?
-Do any USB peripherals work - keyboard, mouse, iOS device, or is it just external drives?
First of all, do Basic hardware testing. If it not gets resolved then Reset USB Ports. After doing both these steps and if you still face same problem then Reset SMC. If you still face same problem then follow this article. I hope this will help you.
