- Oct 7, 2017
Hello, I'm a long time mac user, photographer and graphic designer. Love my 28"iMac, but it was time for a new MacBook pro for on the road. I immediately worried about the new USB-C situation, but Apple assured me I'd be ok with adapters until USB-C becomes more widely used. So I bought an adapter, with a single output, and used a hub that I had. it worked, but would often eject my external HD and mouse and wacom would randomly stop working, I'd have to unplug and plug it back in, which I know is not good for the hard drives. Looking at it closer, I remembered I'd had the hub many years, and was USB2. So I decided, my fault, using old equipment, so I ordered a hub that goes into USB C but has 7 USB 3 ports.
It works great with my external hard drives ( one for time machine backup, and the other for large working files) but the cordless mouse and my Wacom Intuos (Model CTH-480) doesn't work at all with that hub. They work fine with the first adapter I bought, but that means not using both a mouse and a wacom, unless, I plug and unplug, or maybe buy yet another adapter!!!! SCREAM! My iMac is older and USB2. All works fine directly into that machine.
I purchased the 7 port USB on eBay. I know, I know, it was $15 and no manufacturers name on it. , when most of the hubs are $75. I emailed the seller and they said I could send it back, or they would reimburse me half of the purchase price.
Does anyone have any idea why my HDs work but not the mouse and wacom?
