- Sep 27, 2014
Hi! I opened up my macbook pro today to find that the trackpad suddenly, randomly was not working. The cursor only responds to touch on the very top and bottom edges. The entire middle section does not respond to my fingers no matter what I do. However, I can click anywhere on the trackpad and it still works (except the very top edge, but I'm thinking that's normal)! I just cannot move the cursor around.
The only thing that I did to the computer was move it from room to room. Nothing has been spilled on it. I tried blowing a little compressed air around the edges, as well as cleaning them out with the corner of a piece of paper. I also tried holding the macbook at different angles and clicking/shaking/tapping it gently to try to dislodge any debris.
I think i bought this computer about 2011. It is a 13 inch macbook pro. It is the unibody design where you can't take the battery out.
Please help! I don't live anywhere near an apple store, nor do I have any desire to enter that high tech hellscape! I'd rather fix it myself if I can.
Thanks!!!!
Thanks!!!!
