- Jan 31, 2017
Hello. Please help me.
MBP late 2013, A1398.
I have set firmware password when buy it for about 3 years ago and never used this password, so i forgot it. I haven't order from the store so I can't use Apple's help. So I read some forums, watch YouTube videos and decided to reset password by flashing EFI chip with clean firmware (found on https://ghostlyhaks.com/downloads/efi-repository by EMC number: 2674). I successfully replace two serial numbers (12 and 17 digits) in clean firmware with my ones, erase chip and write new program.
But something goes wrong and now I have:
- no more firmware password - good news;
- MacBook loading too slow: about 20 seconds between powering on and chime;
- CMD-R mode not loading (progress bar under the apple slowly fulfilled and then nothing happens);
- CMD-OPT-R mode loads normally, gave me access to utilities so I formatted my HD (disk verified and seems to be OK);
- bootable USB flash drive with macOS Sierra image also loading very slow and nothing happening when progress bar filled. Another MBP loads from this drive in about 3-5 minutes.
Yes, I know all what I did was a bad idea.
So... What's the problem and is there a solution to fix it?
