- Nov 1, 2016
I’ve got and early 2011 macbook pro. 15”, i7, 8gb ram. Last year I had to use the Macbook pro extension repair programme and all was good.
While my Macbook was broken I had to buy a Mac mini to tide me over as I use it every day in my business and as a result my Macbook pro has seen little use since its repair however, when I have used it, it seems incredibly slow, so slow in fact that it was virtually unusable.
I installed El Capitan and it was still slow. It turned out that the battery had died so I replaced the battery and it speeded up a bit but was still slow.
A few weeks ago things started to get worse. In no particular order.
The screen freezes or locks up.
The screen freezes or locks up and the curser disappears.
I get the blue screen of death.
I get a grey screen.
It suddenly restarts with no message.
I get a message, your computer will restart because of a problem.
It gets stuck in a startup loop which goes on forever until switched off over night.
The screen splits in two with the left half going to the right and the right to the left.
I get black lines across the screen and funny colours.
The Z key has stopped working.
On start up, the Apple logo and progress bar show then the screen goes grey, then a line appears across the centre of the screen than looks like a normal screen compressed into about half an inch and then the Apple logo and progress bar reappears and it starts up and works normally for an indefinite time then it all starts again or the screen goes black and nothing happens.
All of the above happen when started in safe mode as well.
I have replaced the hard drive. Reinstalled everything from the Mac mini, which is working fine. Reinstalled El Capitan and now installed Sierra and nothing has worked, all the problems still exist.
I’ve run AHD and all it comes back with is 4xxx/4/40000005 battery but the battery is OK.
Where can I go from here?
