MacBook Pro mid 2009 sleep problem
Hi, sorry if my post is not as comprehensive as necessary. I just bought my first used Mac yesterday (Saturday) and I just realized a slight problem. When I close the lid for the MacBook to go to sleep, it undergoes an endless cycle of going to sleep then turning back on. I disabled "Wake for Network Access" on the power options and bluetooth. I've done a SMC? restart and pulled out the .com.apple.autowake.plist onto my desktop and re-booted. When I force sleep from the apple menu, the sleep light "breathes" normal though sometimes I still hear the fans going (is this normal?) but when I close my lid, the light will go off as if sleeping, then turn on for several seconds and repeat. I have no USB devices connected or peripherals. I've quit all my running programs, but still the same thing happens. Specs on the MacBook are: MacBook Pro 13-inch Mid 2009, Mac OS X Lion 10.7.2(11C74 but soon to update though) 2.26 GHz Intel Core 2 Duo, 4GB 133 MhZ DDR3, NVIDIA GeForce 9400M 256 MB.
On the console it says:
2/5/12 6:51:10.000 PM kernel: Wake reason: EHC1
2/5/12 6:51:10.000 PM kernel: Previous Sleep Cause: 5
2/5/12 6:51:10.000 PM kernel: USB (EHCI):port 5 on bus 0x24 connected or disconnected: portSC(0x301402)
2/5/12 6:51:10.000 PM kernel: An Unknown USB Device (Port 5 of Hub at 0x24000000), may have caused a wake by being connected
2/5/12 6:51:11.000 PM kernel: 00000000 00000020 NVEthernet::setLinkStatus - not Active
2/5/12 6:51:13.000 PM kernel: MacAuthEvent en1 Auth result for: 1c:af:f7:cc:fd:e1 No Ack
2/5/12 6:51:14.000 PM kernel: Graphics suppressed 4533 ms
2/5/12 6:51:15.000 PM kernel: MacAuthEvent en1 Auth result for: 1c:af:f7:cc:fd:e1 No Ack
2/5/12 6:51:19.000 PM kernel: hibernate image path: /var/vm/sleepimage
2/5/12 6:51:19.000 PM kernel: sizeof(IOHibernateImageHeader) == 512
2/5/12 6:51:19.000 PM kernel: Opened file /var/vm/sleepimage, size 4294967296, partition base 0x0, maxio 400000 ssd 0
2/5/12 6:51:19.000 PM kernel: hibernate image major 14, minor 0, blocksize 512, pollers 5
2/5/12 6:51:19.000 PM kernel: hibernate_alloc_pages flags 00000000, gobbling 0 pages
2/5/12 6:51:19.000 PM kernel: hibernate_setup(0) took 0 ms
2/5/12 6:51:19.000 PM kernel: 00000000 00000020 NVEthernet::setLinkStatus - not Active
2/5/12 6:51:21.000 PM kernel: hibernate_page_list_setall start 0xffffff806535b000, 0xffffff806602d000
2/5/12 6:51:21.000 PM kernel: hibernate_page_list_setall time: 180 ms
2/5/12 6:51:21.000 PM kernel: pages 520918, wire 78717, act 116772, inact 5838, spec 337, zf 13353, throt 0, could discard act 47095 inact 40909 purgeable 3891 spec 214006
2/5/12 6:51:21.000 PM kernel: hibernate_page_list_setall found pageCount 215017
2/5/12 6:51:21.000 PM kernel: IOHibernatePollerOpen, ml_get_interrupts_enabled 0
2/5/12 6:51:21.000 PM kernel: IOHibernatePollerOpen(0)
2/5/12 6:51:21.000 PM kernel: IOPolledInterface::checkForWork[5] 0xe00002eb
2/5/12 6:51:21.000 PM kernel: PMStats: Hibernate write took 1 ms
2/5/12 6:51:21.000 PM kernel: all time: 1 ms, comp bytes: 0 time: 0 ms 0 Mb/s, crypt bytes: 0 time: 0 ms 0 Mb/s,
2/5/12 6:51:21.000 PM kernel: image 0, uncompressed 0 (0), compressed 0 (0%), sum1 e2da656f, sum2 0
2/5/12 6:51:21.000 PM kernel: wired_pages_encrypted 0, wired_pages_clear 0, dirty_pages_encrypted 0
2/5/12 6:51:21.000 PM kernel: hibernate_write_image done(e00002eb)
2/5/12 6:51:21.000 PM kernel: sleep
2/5/12 6:51:22.000 PM kernel: Wake reason: EHC1
2/5/12 6:51:22.000 PM kernel: Previous Sleep Cause: 5 (repeats)
It mentions hibernate stuff and wake reason: EHC1, port 5, unknown USB device etc. Are there any suggestions or input? If any more information needs to be provided, let me know. Thanks in advance.
Thanks for the quick reply. No, I do not have Candelair installed (unless it was previously installed and left some files). iWork/iLife and Microsoft Office came installed with the computer. I installed smcFanControl and Dropbox. I've disabled Dropbox but the problem persists.
It seems the MacBook is turning on and off regardless of a closed lid or not. Upon removing the bottom casing however, the problem disappeared. The MacBook actually slept. Any thoughts?
