I'm mainly a windows man but as the local computer geek Ive been given a Macbook pro to sort out that is going soooooooooooooooooo slow
13 inch mid 2012
2.5GHz i5
4GB
500GBB HDD
El Capitan 10.11.6
It originally came with Mavericks installed
I have ran the disk check utility and it found something like this "invalid disk label cksum mismatch" but said everything else was OK
Are I correct in thinking that if I do a time machine backup, then reinstall El Capitan from a USB stick that I will download and create, then after the install I can recover from the backup all the original programs and documents etc?
Does the Time machine backup contain all the user data?
So far its done 5GB of 131GB of the backup and says it will take 17 hours more, is this normal?
Thanks
13 inch mid 2012
2.5GHz i5
4GB
500GBB HDD
El Capitan 10.11.6
Thanks
