Macbook Pro charging issues/kernel panic
Hi!
I don't know if this has been discussed already. After extended searching I never quite found someone with the exact same issues I'm experiencing:
For some days now my MacBook Pro 13" 2017 i5 (no Touch Bar) gets noticeably hot and crashes while being charged and in sleep mode/or being shut down. (question mark folder of death appearing on screen) After hard shutdown it usually reboots just fine and operates normally.
I already tried:
- resetting SMC, PRAM, NVRAM
- Disk Utility tool as well as Apple Diagnostics showed no hard disk or other hardware problems
- eventually I erased my hard drive and reinstalled MacOS Ventura
Unfortunately the issue persists.
If it's of any help, error message after reboot reads:
panic(cpu 0 caller 0xffffff800c78d676): nvme: "AppleS3XController. PCI link down. Write. ID=0xffffffff ARG1=0xffffffff ARG2=0xffffffff ARG3=0xffffffff EDD0=0xffffffff EDD1=0xffffffff EDD2=0xffffffff EDD3=0xffffffff EDD4=0xffffffff EDD5=0xffffffff EDD6=0xffffffff EDD7=0xffffffff NANDV=0x2, DRAMV=0x2, SSDC=256G.\n" @IONVMeController.cpp:6151
Panicked task 0xffffff8ba88f5208: 175 threads: pid 0: kernel_task
Backtrace (CPU 0), panicked thread: 0xffffff9543593598, Frame : Return Address
Does someone have an idea what's causing this?
Many thanks in advance,
S.
If you performed a clean install, it sounds like there may be some form of hardware issue that isn't being identified for some reason. When you performed the erase & install, did you add any third-party software that may have triggered the kernel panic, or did it happen with just macOS installed?
Hello, l've the same issue, here is the crash report. l don't have a third party software... Thank you for your help
panic(cpu 0 caller 0xffffff801b9e6676): nvme: "AppleS3XController. PCI link down. Write. ID=0xffffffff ARG1=0xffffffff ARG2=0xffffffff ARG3=0xffffffff EDD0=0xffffffff EDD1=0xffffffff EDD2=0xffffffff EDD3=0xffffffff EDD4=0xffffffff EDD5=0xffffffff EDD6=0xffffffff EDD7=0xffffffff NANDV=0x2, DRAMV=0x1, SSDC=256G.\n" @IONVMeController.cpp:6151
Panicked task 0xffffff9036d98208: 173 threads: pid 0: kernel_task
Backtrace (CPU 0), panicked thread: 0xffffff8b69aa9598, Frame : Return Address
0xffffffaaabd0baa0 : 0xffffff80191eb38d
0xffffffaaabd0baf0 : 0xffffff8019358ed6
0xffffffaaabd0bb30 : 0xffffff8019348120
0xffffffaaabd0bb80 : 0xffffff8019185951
0xffffffaaabd0bba0 : 0xffffff80191eb66d
0xffffffaaabd0bc90 : 0xffffff80191ead19
0xffffffaaabd0bcf0 : 0xffffff80199e072b
0xffffffaaabd0bde0 : 0xffffff801b9e6676
0xffffffaaabd0bdf0 : 0xffffff801b9c97db
0xffffffaaabd0be20 : 0xffffff80199196f6
0xffffffaaabd0be70 : 0xffffff8019919608
0xffffffaaabd0bea0 : 0xffffff8019244c98
0xffffffaaabd0bee0 : 0xffffff8019245d4b
0xffffffaaabd0bfa0 : 0xffffff801918519e
Kernel Extensions in backtrace:
com.apple.iokit.IONVMeFamily(2.1)[C334C31D-7F48-3BE5-A0A4-108210D621D0]@0xffffff801b9c1000->0xffffff801b9edfff
dependency: com.apple.driver.AppleMobileFileIntegrity(1.0.5)[DB38BB35-D38C-3110-9B53-0D2927F702CF]@0xffffff801a7c5000->0xffffff801a7f3fff
dependency: com.apple.iokit.IOPCIFamily(2.9)[802B9CA4-B851-396E-8DA4-B30E751EC48F]@0xffffff801bc59000->0xffffff801bc88fff
dependency: com.apple.iokit.IOReportFamily(47)[D8F664BF-70CB-3596-A4D5-35E72EBC36EE]@0xffffff801bc9a000->0xffffff801bc9cfff
dependency: com.apple.iokit.IOStorageFamily(2.1)[62F2C392-9547-33CB-8E12-6F77B7B052AF]@0xffffff801bd8c000->0xffffff801bda2fff
Process name corresponding to current thread (0xffffff8b69aa9598): kernel_task
Mac OS version:
22D68
Kernel version:
Darwin Kernel Version 22.3.0: Mon Jan 30 20:42:11 PST 2023; root:xnu-8792.81.3~2/RELEASE_X86_64
Kernel UUID: 10E5D254-4A37-3A2A-B560-E6956A093ADE
roots installed: 0
KernelCache slide: 0x0000000018e00000
KernelCache base: 0xffffff8019000000
Kernel slide: 0x0000000018edc000
Kernel text base: 0xffffff80190dc000
__HIB text base: 0xffffff8018f00000
System model name: MacBookPro14,1 (Mac-B4831CEBD52A0C4C)
System shutdown begun: NO
Panic diags file available: YES (0x0)
Hibernation exit count: 57
System uptime in nanoseconds: 13556923195254
Last Sleep: absolute base_tsc base_nano
Uptime : 0x00000c547797685e
Sleep : 0x00000c378714becb 0x0000171edbb979ea 0x00000c2f514fbf2a
Wake : 0x00000c37946acb49 0x0000173910f706a8 0x00000c3791ef5a45
Compressor Info: 1% of compressed pages limit (OK) and 1% of segments limit (OK) with 1 swapfiles and OK swap space
Zone info:
Zone map: 0xffffff803660c000 - 0xffffffa03660c000
. PGZ : 0xffffff803660c000 - 0xffffff803760d000
. VM : 0xffffff803760d000 - 0xffffff8504073000
. RO : 0xffffff8504073000 - 0xffffff869d93f000
. GEN0 : 0xffffff869d93f000 - 0xffffff8b6a3a5000
. GEN1 : 0xffffff8b6a3a5000 - 0xffffff9036e0b000
. GEN2 : 0xffffff9036e0b000 - 0xffffff9503871000
. GEN3 : 0xffffff9503871000 - 0xffffff99d02d8000
. DATA : 0xffffff99d02d8000 - 0xffffffa03660c000
Metadata: 0xffffffa076da0000 - 0xffffffa096da0000
Bitmaps : 0xffffffa096da0000 - 0xffffffa099da0000
last started kext at 10479235953: >AudioAUUC 1.70 (addr 0xffffff7faedde000, size 12288)
last stopped kext at 429908041799: >!AThunderboltEDMSink 5.0.3 (addr 0xffffff7faecee000, size 32768)
loaded kexts:
>AudioAUUC 1.70
>X86PlatformShim 1.0.0
>AGPM 131
>!APlatformEnabler 2.7.0d0
@filesystems.autofs 3.0
>!AGraphicsDevicePolicy 7.1.18
>!AHDA 400.3
@AGDCPluginDisplayMetrics 7.1.18
>!AUpstreamUserClient 3.6.9
>pmtelemetry 1
@filesystems.nfs 1
|IOUserEthernet 1.0.1
>usb.!UUserHCI 1
>!A!IPCHPMC 2.0.1
>!ACameraInterface 7.13.0
>eficheck 1
>!A!IKBLGraphics 20.0.2
>!A!IKBLGraphicsFramebuffer 20.0.2
>!AHV 1
>!ADiskImages2 198.40.3
>!A!ISlowAdaptiveClocking 4.0.0
>!ABacklight 180.8
>!ASMCLMU 212
>!AMCCSControl 1.16
>!AThunderboltIP 4.0.3
>!AFileSystemDriver 3.0.1
@filesystems.tmpfs 1
@filesystems.lifs 1
@filesystems.apfs 2142.81.1
@filesystems.hfs.kext 627.40.1
@BootCache 40
@!AFSCompression.!AFSCompressionTypeZlib 1.0.0
@!AFSCompression.!AFSCompressionTypeDataless 1.0.0d1
>!ATopCaseHIDEventDriver 6000.22
>AirPort.BrcmNIC 1400.1.1
@private.KextAudit 1.0
>!ASmartBatteryManager 161.0.0
>!AACPIButtons 6.1
>!ARTC 2.0.1
>!ASMBIOS 2.1
>!AACPIEC 6.1
>!AAPIC 1.7
$!AUserConsent 1
@!ASystemPolicy 2.0.0
@nke.applicationfirewall 403
|IOKitRegistryCompatibility 1
|EndpointSecurity 1
@Dont_Steal_Mac_OS_X 7.0.0
@kec.Compression 1
@kec.!AEncryptedArchive 1
>!AGraphicsControl 7.1.18
>DspFuncLib 400.3
@kext.OSvKernDSPLib 530
@kext.triggers 1.0
>IOHIDPowerSource 1
|IO!BSerialManager 9.0.0
|IO!BPacketLogger 9.0.0
>!AHDA!C 400.3
|IOHDA!F 400.3
|IOAudio!F 400.3
@vecLib.kext 1.2.0
>!A!ILpssUARTv1 3.0.60
>!A!ILpssUARTCommon 3.0.60
>!AOnboardSerial 1.0
|IO!BHost!CUSBTransport 9.0.0
|IO!BHost!CUARTTransport 9.0.0
|IO!BHost!CTransport 9.0.0
|IOAccelerator!F2 475
>IO!BHost!CPCIeTransport 9.0.0
|IOAVB!F 1120.2
|CSR!BHost!CUSBTransport 9.0.0
|Broadcom!BHost!CUSBTransport 9.0.0
|Broadcom!B20703USBTransport 9.0.0
>!ARSMChannel 1
|IORSM!F 1
>!AIPAppender 1.0
@!AGPUWrangler 7.1.18
|IOSlowAdaptiveClocking!F 1.0.0
@!AGraphicsDeviceControl 7.1.18
>!ABacklightExpert 1.1.0
|IONDRVSupport 597
@plugin.IOgPTPPlugin 1110.13
>X86PlatformPlugin 1.0.0
>IOPlatformPlugin!F 6.0.0d8
|IOGraphics!F 597
>!ASMBus!C 1.0.18d1
>!AThunderboltDPOutAdapter 8.5.1
>driverkit.serial 6.0.0
|IOSerial!F 11
>!AThunderboltPCIDownAdapter 4.1.1
>!AThunderboltDPInAdapter 8.5.1
>!AThunderboltDPAdapter!F 8.5.1
>!AHPM 3.4.4
>!A!ILpssI2C!C 3.0.60
>!AXsanScheme 3
>!ABSDKextStarter 3
|IOSurface 334.0.1
@filesystems.hfs.encodings.kext 1
>!ASyntheticGame!C 10.4.1
>!AActuatorDriver 6400.44
>!AHIDKeyboard 231
>!AMultitouchDriver 6400.44
>!AInputDeviceSupport 6430.1
>!AHS!BDriver 6000.22
>IO!BHIDDriver 9.0.0
>!AHSSPIHIDDriver 63
>!AThunderboltNHI 7.2.81
|IOThunderbolt!F 9.3.3
>!AHSSPISupport 63
|IO80211!FLegacy 1200.12.2b1
>corecapture 1.0.4
|IONVMe!F 2.1.0
>!A!ILpssSpi!C 3.0.60
>!A!ILpssDmac 3.0.60
>usb.!UHostPacketFilter 1.0
|IOUSB!F 900.4.2
>!A!ILpssI2C 3.0.60
>!A!ILpssGspi 3.0.60
>usb.!UXHCIPCI 1.2
>usb.!UXHCI 1.2
>!AEFINVRAM 2.1
>!AEFIRuntime 2.1
|IOSMBus!F 1.1
|IOHID!F 2.0.0
|IOTimeSync!F 1110.13
|IOSkywalk!F 1.0
>mDNSOffloadUserClient 1.0.1b8
|IONetworking!F 3.4
>DiskImages 493.0.0
|IO!B!F 9.0.0
|IOReport!F 47
$quarantine 4
$sandbox 300.0
@kext.!AMatch 1.0.0d1
>!ASSE 1.0
>!AKeyStore 2
>!UTDM 547
|IOUSBMass!SDriver 232
|IOSCSIBlockCommandsDevice 476.81.2
|IO!S!F 2.1
|IOSCSIArchitectureModel!F 476.81.2
>!AMobileFileIntegrity 1.0.5
$!AImage4 5.0.0
@kext.CoreTrust 1
>!AFDEKeyStore 28.30
>!AEffaceable!S 1.0
>!ACredentialManager 1.0
|CoreAnalytics!F 1
>KernelRelayHost 1
|IOUSBHost!F 1.2
>!UHostMergeProperties 1.2
>usb.!UCommon 1.0
>!ABusPower!C 1.0
>!ASEPManager 1.0.1
>IOSlaveProcessor 1
>!AACPIPlatform 6.1
>!ASMC 3.1.9
|IOPCI!F 2.9
|IOACPI!F 1.4
>watchdog 1
@kec.pthread 1
@kec.Libm 1
@kec.corecrypto 12.0
And l've the same MacBook Pro 2017, it's been 6 month now l've this issue and never before, l didn't do anything particular...
This just started happening to me as of a week or two ago -- usually overnight when it's on sleep mode (with charger), wake up to find the question mark folder of death. Couple of times it green screened too.
Same model: MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports), no touch bar, 2.3 GHz Dual-Core Intel Core i5, Intel Iris Plus Graphics 640 1536 MB
panic(cpu 0 caller 0xffffff801f3876a2): nvme: "AppleS3XController. PCI link down. Write. ID=0xffffffff ARG1=0xffffffff ARG2=0xffffffff ARG3=0xffffffff EDD0=0xffffffff EDD1=0xffffffff EDD2=0xffffffff EDD3=0xffffffff EDD4=0xffffffff EDD5=0xffffffff EDD6=0xffffffff EDD7=0xffffffff NANDV=0x2, DRAMV=0x2, SSDC=128G.\n" @IONVMeController.cpp:6090
Panicked task 0xffffff950e6e0670: 182 threads: pid 0: kernel_task
Backtrace (CPU 0), panicked thread: 0xffffff8b75e48aa0, Frame : Return Address
