Hi everyone,
I have the following problem. My MBP won't charge correctly. Here are the symptoms:
- Magsafe adapter LED stays off when connected
- Mac OS tells me that the charger is connected, but the battery is not charging
- When I shut down my Macbook and let it sit for a while (with Magsafe connected) it will slowly (very slowly, think 12+ hours) charge to full, and it behaves normally (posting from it right now).
What I have tried:
- Different Magsafe adapter (with sufficient wattage)
- Popped in a different battery (same model which charges fine in another Macbook)
- Reset SMC
I tried to google my problem, but I haven't found someone with my particular problem, either they can charge or not. But I can charge it (like I mentioned, slowly) when shut down.
Does anyone know what to do? I have to mention, that I recently "rediscovered" this Macbook, it wasn't powered on in years. I just upgraded to Yosemite, if that's important.
Thanks in advance,
Julian
What I have tried:
- Reset SMC
Thanks in advance,
Julian
