- Feb 13, 2016
Hello again, this was my previous thread a while back, and while I was able to successfully replace the logic board with a new one that I ordered, the problem seemingly fixed itself, but then didn't.
The battery charges fine, but there is no boot no matter what I do. I suspect this may be a problem with the PRAM battery, located underneath the logic board on this model macbook, as I think the PRAM battery is responsible for that turn-on instant, and if it's dead or dying, it won't do anything when you press the power button.
Am I correct in suspecting it? Would replacing it be a good way to get the machine back up and running? If not, what else could be the problem? Thanks!
