- Aug 13, 2007
Ive had my mac mini for about a year and all of the sudden its ability to run discs has died. When I try a DVD it says there is an initialization error and can't eject the disc. I had to hold down my mouse as it was restarting to get it out. Does anyone know why or how to fix this problem? It seemed like it just died. It is not reading any type of disc, so whatever you stick inside of it basically doesnt exist.
PS: And I just got a disc caught in it and can't get it out even after holding the mouse. I think what happened its that my external dvd burner was on and hooked up and it ejected the burner instead so now it thinks there is absolutely nothing inside so holding down the mouse doesnt work. HELP!
