Mac Mail Problems Help Please, Please
Big problems, really big. Running Monterray.
Sr. Citizen, very, so please put up with me a bit.
Not that computer savvy anymore.
This am, when I went to get my Mail (Apple Mail I think), it said I couldn't
until I upgrade to newest version. So, I clicked on the upgrade box.
**Is this upgrade legitimate ?
I tried, but it had the screen showing it was updating, for over an hour.
Obviously hung up.
Now, upon doing a full re-starting, several tries, all I get is a totally black screen. Totally.
The mouse's arrow does show, though.
What is (likely) happening ? Virus ?
What should I do now ?
is there some kind of a "safe-mode" starting ?
should I click on the eMail upgrade again, assuming it shows again ?
Would be most appreciative for any (very explicit, please) help with this.
So very important to me to get going again; lots of medical "stuff," etc.
Thanks,
Bob
Obviously hung up.
Thanks,
Bob
That does sound very suspicious. I have never encountered such a prompt. Apple Mail updates usually come with system or security updates and are transparent to the user. I need to know the exact model of your Mac so we can try steps to reset the system (e.g. SMC, PRAM, etc.).
Tony, a fellow senior ;)
restart holding down the S key on the keyboard, an keep holding till you see a Apple logo. that should put you in "Safe mode" , stops all other things ut the main system loading...it should take no longer than a few seconds to 30 seconds.
if it does not appear, then hold the power button again till the computer shuts down again.
the repeats but this time holding the R key, and this should put you in recovery mode, where you can re-install the system.
I have never heard of Mail asking for an upgrade.. you may have gotten a fake message from a virus, and that is dangerous.
if and when you finally get a desktop up and running, run a Virus or malwear seeking program..
when asking for help, best to state the computer model and year, AND operating system version.
In a normal installation hang, and I have had a few, you may end up with a 'Kernel' Panic, depending on you model computer and OS..
many different models and OS's occasional have different methods that you can use to get back to a working desk top.
regards, Sandy. (70 and not out yet)
print this out and stick it on he compare below the screen. regards, Sandy
