Mac air discharge battery immediately when power cord removed
Hello Everyone,
I have mac air MacBook Air (13-inch, 2017), It recently shutdown or goes sleep with in few seconds after power cord is removed, it leads to use laptop always power cord connected. I noticed batter health showing "service" flag.
Some of the questions!
1. Do I need to replace the battery?
2. Is it okay to buy and install on own, If yes where can I buy and what is the suitable battery ?
Health Information:
Cycle Count: 713
Condition: Service Battery
Battery Installed: Yes
Amperage (mA): 0
Voltage (mV): 7924
Hardware Overview:
Model Name: MacBook Air
Model Identifier: MacBookAir7,2
Processor Name: Intel Core i5
Processor Speed: 1.8 GHz
Number of Processors: 1
Total Number of Cores: 2
L2 Cache (per Core): 256 KB
L3 Cache: 3 MB
Memory: 8 GB
Boot ROM Version: 195.0.0.0.0
SMC Version (system): 2.27f2
Battery Information:
Model Information:
Serial Number: C0173550Y0PF90LF7
Manufacturer: DP
Device Name: bq20z451
Pack Lot Code: 0
PCB Lot Code: 0
Firmware Version: 511
Hardware Revision: 000a
Cell Revision: 1210
Charge Information:
Charge Remaining (mAh): 2283
Fully Charged: No
Charging: No
Full Charge Capacity (mAh): 2616
Health Information:
Cycle Count: 713
Amperage (mA): 0
Voltage (mV): 7924
System Power Settings:
AC Power:
System Sleep Timer (Minutes): 1
Disk Sleep Timer (Minutes): 10
Display Sleep Timer (Minutes): 10
Wake on AC Change: No
Wake on Clamshell Open: Yes
Wake on LAN: Yes
AutoPowerOff Delay: 28800
AutoPowerOff Enabled: 1
Current Power Source: Yes
DarkWakeBackgroundTasks: 1
Display Sleep Uses Dim: Yes
GPUSwitch: 2
Hibernate Mode: 3
PrioritizeNetworkReachabilityOverSleep: 0
Standby Delay: 10800
Standby Enabled: 1
Battery Power:
Display Sleep Timer (Minutes): 2
DarkWakeBackgroundTasks: 0
GPUSwitch: 2
Hibernate Mode: 3
Reduce Brightness: Yes
Standby Enabled: 1
Hardware Configuration:
UPS Installed: No
AC Charger Information:
Connected: Yes
Wattage (W): 45
Family: 0x00ba
Serial Number: 0x01941c03
Charging: No
Thanks for your thoughts!
