Library not loaded? What is Frameworks and why is it missing?
I have numerous applications that fail to open due to this problem:
Link (dyld) error:
Library not loaded: /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLSystem.dylib
Referenced from: /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLDriver.bundle/GLDriver
Reason: no suitable image found. Did find:
/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLSystem.dylib: unknown file type, first eight bytes: 0x41 0x50 0x50 0x4C 0x3F 0x3F 0x3F 0x3F
What is Frameworks? How can I replace it if it's missing? I recently acquired a copy of Tiger OSX. Is there a way to only reinstall the necessary missing components or do I need to completely reinstall and start over?
Programs affected include Quicktime, Firefox fullscreen, Adobe Photoshop CS4 and CS3, VLC, Dreamweaver, and countless others. As you can see, using my computer just got heaps less fun.
