Leopard - Bootcamp Problems
Hey,
I'm having a little trouble with Bootcamp. I'm running Leopard on my Macbook.
I partitoned the hard drive, and then restarted (like how the installation & setup guide says to!), but now when I go back into Bootcamp it's still the introduction window.
Clicking continue pops up the message that the startup disk now doesn't have enough space to be partitioned, so I assume that the partitioning was completed, but I can't find any Windows Installer.
Am I just being blockheaded and missing something completely obvious? Is there a way to remove the partition without using Bootcamp Assistant, so I can start over? Any help would be very much appreciated!
SD
