- May 19, 2016
Hello everyone
I am experiencing some issues on my LAN network from my mac book pro. I am trying to connect to LAN servers on various different pieces of software running on different machines but my mac is unable to pickup and connect to the external servers on 127.0.0.1.
I have the suspicion that it could be something to do with my localhost connection. I cannot connect to 127.0.0.1 when I use “Ping 127.0.0.1” or “Ping Localhost”, it returns nothing.
Further information;
I can connect to the internet fine.
I have a default hosts file
I have disabled my firewalls and my little snitch program
I am running a Mac book pro on OSX Mavericks 10.9.2
Here are a few commands that I have found from other support threads that could be relevant in diagnosing the problem,
Dig localhost
; <<>> DiG 9.8.3-P1 <<>> localhost
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 11015
;; flags: qr aa rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 0
;; QUESTION SECTION:
;localhost. IN A
;; ANSWER SECTION:
localhost. 0 IN A 127.0.0.1
;; Query time: 3 msec
;; SERVER: 192.168.1.1#53(192.168.1.1)
;; WHEN: Thu May 19 22:48:02 2016
;; MSG SIZE rcvd: 43
ifconfig
lo0: flags=8149<UP,LOOPBACK,RUNNING,PROMISC,MULTICAST> mtu 16384
options=3<RXCSUM,TXCSUM>
inet6 ::1 prefixlen 128
inet 127.0.0.1 netmask 0xff000000
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
nd6 options=1<PERFORMNUD>
gif0: flags=8010<POINTOPOINT,MULTICAST> mtu 1280
stf0: flags=0<> mtu 1280
en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
options=10b<RXCSUM,TXCSUM,VLAN_HWTAGGING,AV>
ether a8:20:66:48:03:bd
media: autoselect (none)
status: inactive
en1: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether 5c:96:9d:82:39:93
inet6 fe80::5e96:9dff:fe82:3993%en1 prefixlen 64 scopeid 0x5
inet 192.168.1.156 netmask 0xffffff00 broadcast 192.168.1.255
media: autoselect
status: active
en2: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
options=60<TSO4,TSO6>
ether d2:00:11:e3:c2:80
media: autoselect <full-duplex>
status: inactive
fw0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 4078
lladdr 10:dd:b1:ff:fe:1e:3c:28
status: inactive
bridge0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
options=63<RXCSUM,TXCSUM,TSO4,TSO6>
ether aa:20:66:84:8d:00
Configuration:
id 0:0:0:0:0:0 priority 0 hellotime 0 fwddelay 0
maxage 0 holdcnt 0 proto stp maxaddr 100 timeout 1200
root id 0:0:0:0:0:0 priority 0 ifcost 0 port 0
ipfilter disabled flags 0x2
member: en2 flags=3<LEARNING,DISCOVER>
ifmaxaddr 0 port 6 priority 0 path cost 0
media: <unknown type>
status: inactive
p2p0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 2304
ether 0e:96:9d:82:39:93
media: autoselect
status: inactive
P.S there is not any information in that code that people could use for malicious attacks is there and If there is could you be kind enough to let me know?
Thank you,
A
Dig localhost
;; Got answer:
;localhost. IN A
;; ANSWER SECTION:
ifconfig
status: inactive
media: autoselect
status: active
status: inactive
status: inactive
Configuration:
status: inactive
media: autoselect
status: inactive
Thank you,
A
