I'm trying to set up a new Lacie Porsche 9220 external drive on a 1.25Gb Dual Processor G4 Mirrordrive running OS X 10.5.8.
I ran erase, formatting to Mac OS Extended (Journaled). But when I try to set up two partitions using Apple Partition Scheme, Disk Utility returns a fail as follows...
'Partition failed with the error: File system formatter failed'.
Also, before partitioning, whilst erasing, the following warning appeared in Disk Utility....
newfs_hfs: WARNING: wrapper option ignored since volume size > 256GB
The DU Log is as follows...
2013-01-19 23:14:03 +0000: Disk Utility started.
2013-01-19 23:17:26 +0000: Preparing to erase : “disk2s10”
2013-01-19 23:17:26 +0000: Partition Scheme: Apple Partition Map
2013-01-19 23:17:26 +0000: 1 volume will be erased
2013-01-19 23:17:26 +0000: Name : “disk2s10”
2013-01-19 23:17:26 +0000: Size : 465.6 GB
2013-01-19 23:17:26 +0000: Filesystem : Mac OS Extended (Journaled)
2013-01-19 23:17:26 +0000: newfs_hfs: WARNING: wrapper option ignored since volume size > 256GB
2013-01-19 23:19:49 +0000: Initialized /dev/rdisk2s10 as a 466 GB HFS Plus volume with a 40960k journal
2013-01-19 23:19:49 +0000: Mounting disk.
2013-01-19 23:20:50 +0000: Could not mount disk2s10 with name disk2s10 after erase
2013-01-19 23:20:50 +0000: Erase complete.
2013-01-19 23:24:17 +0000: Preparing to partition disk: “ST950032 5AS Media”
2013-01-19 23:24:17 +0000: Partition Scheme: Apple Partition Map
2013-01-19 23:24:17 +0000: 2 volumes will be created
2013-01-19 23:24:17 +0000: Partition 1
2013-01-19 23:24:17 +0000: Name : “Boot”
2013-01-19 23:24:17 +0000: Size : 15 GB
2013-01-19 23:24:17 +0000: Filesystem : Mac OS Extended (Journaled)
2013-01-19 23:24:17 +0000: Partition 2
2013-01-19 23:24:17 +0000: Name : “Repository”
2013-01-19 23:24:17 +0000: Size : 450.8 GB
2013-01-19 23:24:17 +0000: Creating partition map.
2013-01-19 23:24:23 +0000: Formatting disk2s5 as Mac OS Extended (Journaled) with name Repository.
2013-01-19 23:26:31 +0000: Partition failed for disk disk2s5 File system formatter failed.
2013-01-19 23:26:32 +0000: Formatting disk2s3 as Mac OS Extended (Journaled) with name Boot.
2013-01-19 23:27:22 +0000: Partition failed for disk (null) File system formatter failed.
2013-01-19 23:27:22 +0000: Partition complete.
2013-01-19 23:27:52 +0000: Eject of “disk2” failed
2013-01-19 23:28:13 +0000: Unmount of “disk2” failed
After all of this the drive/s unmounted and when it returned, the LaCie icon had been replaced by a generic system icon.
I'm really hoping someone recognises something, anything in all of this...?
Thanks
Thanks
