- Feb 12, 2005
Hi
I'm having problems with my external Lacie HD as it will not appear when I switch it on.
It was working perfectly until I unplugged my iMac to give it a dust down and clean my desk, when I hooked everything back up and turned my external it just won't appear.
Having switched the cables around, logging onto another account I inserted the installation disks to see if it would show up there but..it doesn't.
The problems I can think of is either faulty firewire connection cable, which seems to be fine, not bends/cuts or the actual HD itself. Though when i switch it on I can hear it whirling noises, same as usual.
Any help appreciated thanks.
