Issue with my control center (help please)
hey guys,happy new year.
i have a problem after installing and uninstalling soundsource,after uninstalling i noticed that the control panel doesn't open at all (extension process control center(xxx-numbers are always different) exited).
i've tried the following methods to fix it but it didn't work:
mac os update.
booting in safe mode.
deleting the caches.
creating a new profile.
first aid in disk utility.
i completely uninstalled soundsource and all its components but the error with control panel doesn't disappear,only starting the console and running the logs helps:
logs:
swiftui-failure-system settings-accessing environment<<private>>'s value outside of being installed on a view.this will always read the default value and will not update.
swiftui-failure-controlcentersettings-accessing environment<<private>>'s value outside of being installed on a view.this will always read the default value and will not update.
maybe someone has already encountered this or knows how to fix it?
mac os 15.2
macbook air m1
Did you get a solution? I am having the same issue. My Macbook announces the time out loud. The only way to stop it is to access Control Center, and for some reason, it keeps crashing with different "exit" numbers each time.
nope,guys from rogue amoeba said that the problem is not with their software although i told them that the problem started after installing their soft,apple support simply said to reinstall the os
Did you use an application cleaner utility to uninstall the software? It’s necessary to “completely” uninstall software, otherwise there could be leftover files installed by the offending software, and even reinstalling macOS is not a guarantee of complete cleanup. AppCleaner.app is my choice, and have read some good things about PearCleaner.app but haven’t had a chance to try it. DO NOT use CleanMyMac.
I used their uninstaller and manually deleted the remaining files but the error didn't disappear anywhere,even after several os updates the error still appears,i still didn't understand what triggers the system
I didn't reinstall the os because i don't know if it would fix the problem if the even updates didn't solve it
