Is there a way to change the Application-is-on Light? (ex. in post)
Hi all!
I was just wondering if it was possible to change the light that appears below active apps. I mean the light that can be seen just below the app, as seen in the screen shot below.
It would be nice to make it a more noticeable color against the light backdrop of the platform that the apps sit on. Another option might be to make that platform darker, but I don't know how to do that either.
(currently running snow leopard)
Thanks!
no, Apple is headed in the direction of removing those lights altogether. Like the iPad/iPhone when you want an App you tap the icon, when finished you move to another App, this is how OS X will be also in the future, no Quit, no Save everything just works.
To all those who follow, realise that any changes done via MacUtil is unsupportable by forums like this, you're on your own folks.
