is there a difference?
bought a new macbook pro, i hooked up a firewire to my white macbook and migrated all my settings,apps,info etc to macbook pro.
now does the macbook pro have a different set of sys prefs than the macbook?
if so how do i get the new macbook pro sys pref?
running leopaard on both 10.5.2
Hello, if it's not on your dock, you can open System Preferences by going to Applications/System Preferences.
