Is that magsafe will work with my macbook pro ?
Yes, that is the correct 60W MagSafe Power Adapter for a MacBook Pro (13-inch, Late 2011).
Thank you your answer.
I bought my laptop in France because I'm French. Do you think the new magsafe (that I will buy in UK) could make some damages to my Macbook pro ? Or is it the same as if I'd buy it in France ?
No, it will not cause problems with your MacBook. The only thing that is different worldwide on the 60W MagSafe Power Adapters is the plug configuration that goes into the AC mains. The brick and MagSafe end are universal. It is an auto-switching power supply, so you will be just fine.
Even if you were to buy the adapter in the United States, you could simply purchase the correct AC mains plug and attach it for use in Europe.
