Internet not working, ping going through
What type of issue to you think it is?
  • Total voters
So I have a problem. First I'll lay down my that I am using a 2011 Mac Mini with the latest version of Mavericks on it. Ok now heres my problem.
I cannot connect to the internet, via browser or other internet enabled apps. I am able to ping servers through the terminals though.
I did actually delete some files I think are relevant. I first cancelled a memory activity in Activity Monitor that was associated with the root user. I was not using the app it was attached to I have not used for a long time (it was a netnanny daemon i think.) Internet continued to work. I then deleted two startup folders one for HotSpotSheild, and the other for NetNanny. Internet again, continued to work.
I then restarted, and internet has ceased to work, but pings go through. Any ideas? I think it might be a DNS issue, but honestly, I don't know.
Those files you deleted may or may not be responsible, HotSpotShield is a 3rd party app that secures your internet connection from hackers etc & NetNanny is a 3rd party parental control app.
Personally I would start with a call to your ISP's tech support team
It sounds to me like there are still remnants of NetNanny and HotSpotShield being loaded at startup, causing the issue to reappear after a restart. When you stopped those processes via Activity Monitor, you did simply that, stopped them until restart.
I would do a Google search to find out how to manually uninstall those two apps totally, then see if the issue persists. There are probably still a few pieces of them still in the following locations:
Macintosh HD > Library > Application Support
Macintosh HD > Library > Extensions
Macintosh HD > Library > Filesystems
Macintosh HD > Library > LaunchAgents
Macintosh HD > Library > LaunchDaemons
Macintosh HD > Library > Preferences
Macintosh HD > Library > PreferencePanes
Macintosh HD > Library > StartupItems
Let us know how you get on,
Thank you so much for your help. I have not tried anything yet but here is some more info
I deleted the startup folders via Clean My Mac 2, which might have been a problem. NetNanny, which i "uninstalled" a year ago by dragging the app into the trash. It's daemons and startup items continued to run.
Again, thanks for the help, I will post results of what I find. I will also try a different internet, from a desperate ISP
Ok
i found stuff in these folders, so thanks for the help. I restarted, but still nothing Any other ideas?
You could also check to see if the OS X Firewall is enabled and blocking:
Apple > System Preferences > Security & Privacy > Firewall
If it is on, turn it off.
Also, have you tried creating a test user, logging into it, and seeing if the issue persists?
Fire wall is off, that was not the problem. Created a test user and got the NSPOSIXErrorDomain:1 error in safari. Pings still going through.
OK...let's look for more NetNanny/HotSpotShield files I forgot to mention previously:
Macintosh HD > System Folder > Library > Extensions
Macintosh HD > System Folder > Library > LaunchAgents
I found a NetNanny file in the first file you suggested, deleted it, restarted and IT WORKS!!!! :D
Thank you so much! I am currently replying to you via the formerly broken computer. You rock!
Excellent...glad it's finally sorted!
Sorry I missed those files earlier, but at least we finally got to the bottom of it.
Enjoy,
Just-for-the-record … the uninstaller for NetNanny is in the installation .dmg
And there are seriously in-depth instructions for complete removal of HotSpot Shield here
