iMac Shutdown Problem
Late 2013 iMac, OS Catalina
Can anyone tell what is going on here? I assume it is some program that isn't shutting down properly, but I have nothing open. When I try to shut down, most (but not all) times, after a long wait, I get a "Your computer was restarted because of a problem." message. After another long wait, the computer restarts and I get the following long message:
Problem Details and System Configuration
Panic(cpu 2 caller 0xffffff7f862faaae): watchdog timeout: no checkins from watchdogd in 308 seconds (4649 totalcheckins since monitoring last enabled), shutdown in progress
Backtrace (CPU 2), Frame : Return Address
0xffffff81e209bc40 : 0xffffff800571763d
0xffffff81e209bc90 : 0xffffff8005851b25
0xffffff81e209bcd0 : 0xffffff80058436ae
0xffffff81e209bd20 : 0xffffff80056bda40
0xffffff81e209bd40 : 0xffffff8005716d07
0xffffff81e209be40 : 0xffffff80057170f7
0xffffff81e209be90 : 0xffffff8005ebe898
0xffffff81e209bf00 : 0xffffff7f862faaae
0xffffff81e209bf10 : 0xffffff7f862fa486
0xffffff81e209bf50 : 0xffffff7f8634ed9c
0xffffff81e209bfa0 : 0xffffff80056bd13e
Kernel Extensions in backtrace:
com.apple.driver.watchdog(1.0)[6C98691D-0510-3A98-9B62-C8FF0B9E3C99]@0xffffff7f862f9000->0xffffff7f86301fff
com.apple.driver.AppleSMC(3.1.9)[73E3419A-8963-3BB8-8538-1FFDEE1F8583]@0xffffff7f86341000->0xffffff7f8635ffff
dependency: com.apple.iokit.IOACPIFamily(1.4)[0BC116A3-534A-3990-99CB-09DB34A5EFAA]@0xffffff7f862f0000
dependency: com.apple.driver.watchdog(1)[6C98691D-0510-3A98-9B62-C8FF0B9E3C99]@0xffffff7f862f9000
dependency: com.apple.iokit.IOPCIFamily(2.9)[B4389948-0918-363E-8E70-0FBC89B384CA]@0xffffff7f86302000
BSD process name corresponding to current thread: kernel_task
Mac OS version:
19H1030
Kernel version:
Darwin Kernel Version 19.6.0: Mon Apr 12 20:57:45 PDT 2021; root:xnu-6153.141.28.1~1/RELEASE_X86_64
Kernel UUID: BB1171FD-A9E3-3D24-92F7-F4DD45974EFD
Kernel slide: 0x0000000005400000
Kernel text base: 0xffffff8005600000
__HIB text base: 0xffffff8005500000
System model name: iMac14,3 (Mac-77EB7D7DAF985301)
System shutdown begun: YES
Panic diags file available: YES (0x0)
System uptime in nanoseconds: 98181584939081
last loaded kext at 51431650525384: >!A!BMultitouch 97 (addr 0xffffff7f89306000, size 53248)
last unloaded kext at 13836867237347: >!AInputDeviceSupport 3440.8 (addr 0xffffff7f89322000, size 110592)
loaded kexts:
com.getdropbox.dropbox.kext 1.13.0
>!A!BMultitouch 97
@filesystems.smbfs 3.4.4
>AudioAUUC 1.70
@AGDCPluginDisplayMetrics 5.2.7
@fileutil 20.036.15
>!AHV 1
|IOUserEthernet 1.0.1
|IO!BSerialManager 7.0.6f8
>AGPM 111.4.4
>X86PlatformShim 1.0.0
>!APlatformEnabler 2.7.0d0
>pmtelemetry 1
>!AUpstreamUserClient 3.6.8
>!AMikeyHIDDriver 131
@Dont_Steal_Mac_OS_X 7.0.0
>!AHDA 283.15
@GeForce 14.0.0
>!A!IHD5000Graphics 14.0.7
>!AMikeyDriver 283.15
>eficheck 1
>!AThunderboltIP 3.1.4
|!ABCM5701Ethernet 10.3.5
>!ASMCLMU 212
>!ALPC 3.1
>AirPort.BrcmNIC 1400.1.1
>!A!ISlowAdaptiveClocking 4.0.0
>!AMCCSControl 1.14
>!A!IFramebufferAzul 14.0.7
@filesystems.autofs 3.0
>!AVirtIO 1.0
@filesystems.hfs.kext 522.100.5
@!AFSCompression.!AFSCompressionTypeDataless 1.0.0d1
@BootCache 40
@!AFSCompression.!AFSCompressionTypeZlib 1.0.0
@filesystems.apfs 1412.141.2
@private.KextAudit 1.0
>!ASDXC 1.7.7
>!AAHCIPort 341.140.1
>!ARTC 2.0
>!AACPIButtons 6.1
>!AHPET 1.8
>!ASMBIOS 2.1
>!AACPIEC 6.1
>!AAPIC 1.7
$!AImage4 1
@nke.applicationfirewall 303
$TMSafetyNet 8
@!ASystemPolicy 2.0.0
|EndpointSecurity 1
>!AMultitouchDriver 3440.1
>!A!BHIDKeyboard 209
>!AHIDKeyboard 209
>IO!BHIDDriver 7.0.6f8
|IOAVB!F 850.1
@plugin.IOgPTPPlugin 840.3
>DspFuncLib 283.15
@kext.OSvKernDSPLib 529
@nvidia.driver.NVDAGK100Hal 14.0.0
@nvidia.driver.NVDAResman 14.0.0
@!AGPUWrangler 5.2.7
|IONDRVSupport 576.1
>!AHDA!C 283.15
|IOHDA!F 283.15
|IOEthernetAVB!C 1.1.0
>!ASMBusPCI 1.0.14d1
|IO80211!F 1200.12.2b1
>mDNSOffloadUserClient 1.0.1b8
>corecapture 1.0.4
|IOSkywalk!F 1
>X86PlatformPlugin 1.0.0
>IOPlatformPlugin!F 6.0.0d8
|IOSlowAdaptiveClocking!F 1.0.0
>!ASMBus!C 1.0.18d1
>!AThunderboltEDMSink 4.2.3
@!AGraphicsDeviceControl 5.2.7
|IOAccelerator!F2 438.7.4
|IOGraphics!F 576.1
@kext.triggers 1.0
|Broadcom!BHost!CUSBTransport 7.0.6f8
|IO!BHost!CUSBTransport 7.0.6f8
|IO!BHost!CTransport 7.0.6f8
|IO!B!F 7.0.6f8
|IO!BPacketLogger 7.0.6f8
>usb.!UHub 1.2
>usb.networking 5.0.0
>usb.!UHostCompositeDevice 1.2
|IOAudio!F 300.2
@vecLib.kext 1.2.0
|IOSerial!F 11
|IOSurface 269.11
@filesystems.hfs.encodings.kext 1
>!AThunderboltDPOutAdapter 6.2.6
>!AThunderboltDPInAdapter 6.2.6
>!AThunderboltDPAdapter!F 6.2.6
>!AThunderboltPCIDownAdapter 2.5.4
|IOAHCIBlock!S 316.100.5
>!AThunderboltNHI 5.8.6
|IOThunderbolt!F 7.6.1
|IOUSB!F 900.4.2
|IOAHCI!F 290.0.1
>usb.!UXHCIPCI 1.2
>usb.!UXHCI 1.2
>!AEFINVRAM 2.1
>!AEFIRuntime 2.1
|IOSMBus!F 1.1
|IOHID!F 2.0.0
$quarantine 4
$sandbox 300.0
@kext.!AMatch 1.0.0d1
>DiskImages 493.0.0
>!AFDEKeyStore 28.30
>!AEffaceable!S 1.0
>!ASSE 1.0
>!AKeyStore 2
>!UTDM 489.120.1
|IOSCSIBlockCommandsDevice 422.120.3
>!ACredentialManager 1.0
>KernelRelayHost 1
>!ASEPManager 1.0.1
>IOSlaveProcessor 1
|IOTimeSync!F 840.3
|IONetworking!F 3.4
|IOUSBMass!SDriver 157.140.1
|IOSCSIArchitectureModel!F 422.120.3
|IO!S!F 2.1
|IOUSBHost!F 1.2
>!UHostMergeProperties 1.2
>usb.!UCommon 1.0
>!ABusPower!C 1.0
|CoreAnalytics!F 1
>!AMobileFileIntegrity 1.0.5
@kext.CoreTrust 1
|IOReport!F 47
>!AACPIPlatform 6.1
>!ASMC 3.1.9
>watchdog 1
|IOPCI!F 2.9
|IOACPI!F 1.4
@kec.pthread 1
@kec.Libm 1
@kec.corecrypto 1.0
That looks like a iMac (21.5-inch, Late 2013) running macOS 10.15.7 Catalina, correct?
Yes it could be a software issue. I do see Dropbox in the panic log - have you been running that for a while and is it up to date?
-How full is the drive?
-Any third-party apps like MacKeeper or antivirus installed?
-Have you tried disconnecting all external devices/peripherals except the keyboard and mouse?
You could try holding the Shift key when powering it on to startup in safe mode. Then shut down completely and then power on.
Thanks. Correct re: iMac and macOS.
Drive has 847.26 GB free. No antivirus or MacKeeper, but I do have SugarSync backup.
It looks life Dropbox is the problem. I turned off "Open at login" and after opening it, quit before shutting down and shut down without a problem.
I have been running it for several years and it is, as far as I can tell, up to date.
I'll wait another day or two before making this as solved, just to make sure.
Thanks again for your help
No worries...
I have seen the Dropbox application cause some issues, but not always.
Keep us posted and be well.
Oops - spoke too soon. The problem recurred yesterday with no sign of Dropbox. (I turned off Open at login and did not open it all day.) The "report" seemed shorter, but I didn't capture it. I'll continue to monitor.
